Hotbox Diesel Heater
Cainen Buchanan
@CainenB ·
POLL
How would you prefer to measure fuel consumption?
- Open the cap and look
- Clear fuel tank
- Digital gauge
Discussion (18)
Toku Akashi
· @SurferDudeToku
Ordered one!
Corey Clarke
· @centerfordiseasecontrol
What's the founder's edition bonus?
B
Brandon W
· @BCW
How many KW is the heater, what brand of Chinese heater are you using in the hotbox?
Jennifer Rey
· @JenRey
Been waiting a long time for this plug and play setup... #17 😁
R
Ron Trickett
· @seniorsolo
How do you clear out the carbon build up? Is there a purge capability that will blow it out?
Biaggo Comeriato
· @Biaggo
Would there be a way to add a clear window slit for the fuel levels?
Biaggo Comeriato
· @Biaggo
#22
Cody Bowden
· @Bowden360
@Jennifer Rey How do you know what number you are?
Jennifer Rey
· @JenRey
@Cody Bowden This was on my confirmation page: "Founders Edition: #17 of 100 — provisional, final number confirmed by payment order"
N
Nate Schaeffer
· @ShadowHunter
How do we prime it when if or when it runs out of fuel? If we lose prime how can we see the air trapped in the black fuel line? How well does that fuel cap seal when going from sea level to 6000’? Fuel level sight glass integrated on one end would be my pick for a fuel gauge.
Cody Bowden
· @Bowden360
@Jennifer Rey Thanks! Im #12 but when i purchased the website didnt have any of the description yet lol, i was too excited
A
Anderson
· @SkiTruk
I like the idea of a clear slit window to see the fuel level. Will there be a power adapter so I can use it in my garage?
Chris McAra
· @giantkeeper
Been waiting a long time for this. I really like the thought that went in to this heater and that it was refined for the LP system. Here’s to less cold feet!
M
Matthew
· @Matthew-Ayers
As long as the tank on the inside is already clear, a very simple “cut out“ on the exterior aluminum housing would allow the user to essentially view the tank level visually. You could further add clarity by adding “tick marks“ or some sort of graphic on the side of the exterior housing. Similar to the photo attached. This seems like an incredibly simple approach, but again would require the actual fuel tank to be clear. As well as the tank to be close enough to the sheet metal housing.
M
Matthew
· @Matthew-Ayers
K
Kirby
· @Kirby
Two questions: 1. What if my port is on the drivers side rear? Can the heater be reversed/ mirrored so that the cold air and hot air ports align? 2. Is there an option to mount it on the interior for transport? Could the hooks hook in the same mount to keep it put when not in use inside the camper? I wouldn’t want it banging around or tipping and spilling.
Jennifer Rey
· @JenRey
@Kirby They offer drivers side and passenger side configuration. On the LP site product page, you select which side your port is on. My port is on the drivers side.
D
DAVID SCOT LAUGHLIN
· @dslaughlingmailcom
Gas Cap with Gauge for Fuel Tank, mechanical - HOTBOX DIESEL HEATER Suggestion
