How to Wire a LP 3rd Brake Light on a Jeep Gladiator JT
Toku Akashi
Toku Akashi @SurferDudeToku ·
Anyone else having trouble figuring out how to wire the 3rd brake light (CHMSL) on a Lone Peak camper to a Jeep Gladiator JT?
I ran into the same problem and finally figured out a clean solution, so I wanted to share it here.
The issue is that the Gladiator’s trailer wiring doesn’t have a dedicated brake-light output. The left and right brake/turn signals are combined, so you can’t simply grab one wire for the camper’s third brake light. If you do, the third brake light will flash with that turn signal.
The solution is a stop logic module — ATC AT-LC-8N.
It takes the left and right Stop/Turn signals and separates the brake signal, giving you a dedicated output for the camper’s third brake light.
Wiring:
  • 🟡 Yellow → Jeep Left Stop/Turn
  • 🟢 Green → Jeep Right Stop/Turn
  • ⚫ Black → Ground
  • 🔴⚪ Red/White → Lone Peak 3rd Brake Light RED (+)
  • ⚫ Lone Peak 3rd Brake Light BLACK → Ground
I tapped the signals at the factory trailer connector, so there was no need to run wires all the way up to the Jeep’s taillights.
The module basically looks at both Stop/Turn circuits and provides a clean brake-only output for the CHMSL.
Brake = 3rd brake light ON
Left turn = 3rd brake light stays OFF
Right turn = 3rd brake light stays OFF
This turned out to be a pretty simple solution once I figured out what was needed.
Hopefully this saves another Gladiator/Lone Peak owner some time! 👍
61 views 7 replies 2 likes
Discussion (7)
Toku Akashi
Toku Akashi · @SurferDudeToku ·
Pictures
Toku Akashi
Pictures
Toku Akashi
Pictures
Jason nickel
Jason nickel · @Wolfoverland ·
Yep. I had to do the same thing!
Toku Akashi
@Jason nickel Took me 2 months to figure this out! Lol
Paul Rein
Paul Rein · @midlife_adventurer ·
Good job and thanks for sharing. I got lucky because I have the diode Dynamics hitch light which basically does the same thing for its own signal and I tapped off that.
Paul Rein
