DIY 2022 Tacoma Tailgate seal
Dain Cummings
Dain Cummings @Dain ·
When I took delivery of my LP the first night I noticed I had a lot of dust in the bed. 6 months later and countless attempts to correct the issue I finally found the ESI tailgate seal. They have a bunch of makes and models available. I will say it is not 100% sealed and I’m sure it will never be but it is a solid 95% and I am happy with that.
Step by Step Overview
List of steps to complete this project:
  • Clean the end of your bed
  • Prep the end of your bed
  • Apply seal
  • Sit back and relax
Overhead view of empty red pickup truck bed with black rubber mat and tailgate down, showing storage capacity for overlanding gear
To clean my tailgate I used Dawn Powerwash and a stiff bristle brush. Get the ends of the bed (pictured and circled in red) nice and wet. Apply your dawn (or cleaner of choice) and SCRUB. Mine had years of dirt, mud, and god knows what else. I wanted to make sure it was as clean as possible. Allow your bed to fully air dry before continuing to step 2.
Amazon Basics 70% Isopropyl Alcohol First Aid Antiseptic 32 Fl Oz bottle product listing with price options and Prime delivery details
I used 70% isopropyl alcohol.
Once dry using a microfiber and isopropyl give the ends you just washed a good wipe down. Removing and final grime or grease that may have been left behind from your scrubbing. I do this twice to make sure it’s as good as possible.
Apply the seal
Close-up of vehicle door hinge mechanisms and red tail light assembly with Milwaukee tool visible in background
Close-up of a vehicle's open rear door showing red taillight assembly, black interior panel, blue wiring, and metal hinges on a paved road with green trees in background
Truck bed view showing Milwaukee tool bag, Coleman cooler, blue instruction manual, and diamond plate toolbox with metal cleats visible on overlanding vehicle
Excuse the mess.
You will get 3 strip of seal in the package. 2 of them are for the sides, the third is for the bottom. For the sides the bulb part of the seals will face each other. And the bottom will face down. Starting on the sides: Start at the bottom and slowly work your way towards the rubber grommet. They will need to be cut at the appropriate length when you meet the grommet. Leaving you with the perfect amount from top of grommet to top of bed. Lightly hold the seal in place until you are happy and then apply pressure to the seal. If you need to try more than once do so BEFORE you apply pressure. From the grommet to the top of the bed follow the curvature of the bed. Repeat on opposite side. For the bottom piece: Start on whichever side you please and place the seal as close as possible to the one on the side wall. The tighter they are the better they will seal. Repeat exactly what you did for the sides applying minimum pressure until you are happy with placement of it. Then push firmly. You will have to trim this piece accordingly also. This was the trickiest one as the gap was relatively tight for my hands to fit into.
Sit back and relax
Once you are done the tailgate will be harder to seal than before. I closed mine like normal and pushed it shut the rest of the way. After a couple days it went back to almost normal. It has worked Amazon this far.
83 views 3 replies 5 likes
Discussion (3)
T
Tanya Daniels · @themtngirl ·
Thank you for posting this. We are working on sealing the tailgate. Where did you get the cover for your tailgate? We are sick of the plastic ridged cover that came on our Tacoma! No where to sit your drinks down without spilling & it’s hard on the knees.
Dain Cummings
Dain Cummings · @Dain ·
@Tanya Daniels The company that made it is MTN Hatch. By far one of the best things I’ve done to the truck. https://mountainhatch.org/products/mountain-hatch-for-2005-2022-toyota-tacoma?variant=45284060201122 They aren’t cheap for what it is at
99 but worth every penny in my opinion. They do a lot of sales online and at Overland expos too. SUPER easy install I have the one linked, they also offer a version that is completely flat. I have the pockets but very rarely use them there is one that is a perfect size for a can and one that is a perfect size for a jetboil. It is 100% a knee saver.
T
@Dain Cummings Thanks Dain!
